SQL Query works in the statement editor, but not when finished
billy.olvestad
Post by billy.olvestad »
I am trying to add a value from an SQL database as private data.
I have an SQL Query that works as long as I am inside the statement builder ("Build SQL statement"-window), but when I finish and insert, the double quotation marks are confused by switch to mean the end of the SQL statement text.
I need the double quotation marks in the SQL statement though, because the columns in the database have spaces and dashes in their names (like for instance "Sell-To Name", that has both).
Is there a way to escape the double quotation marks in the SQL query text so that switch doesn't interpret them as an end to the "Database.Text:SQL"-variable?
This is the SQL Query that works in the statement builder, if I click "Validate statement":
SELECT "Sell-To Name" FROM "åtta_45$PV Case" WHERE "Order No_" = '[Metadata.Text:Path="//field[tag='Ordernummer']/value",Dataset="Submit",Model="XML"]'
When it is inserted into the database variable however, I get errors related to the double quotation marks. This is the code that doesn't work:
[Database.Text:SQL="SELECT "Sell-To Name" FROM "åtta_45$PV Case" WHERE "Order No_" = '[Metadata.Text:Path="//field[tag='Ordernummer']/value",Dataset="Submit",Model="XML"]'",Connection="printvis"]
mkayyyy
Re: SQL Query works in the statement editor, but not when finished
Post by mkayyyy »
You could define the SQL statement as private data
Then just pass the private data variable into the database variable and that should work
billy.olvestad
Hey! That's genious!
Why didn't I think of that?! :D
Thank you! I will be trying that tomorrow.
billy.olvestad
Sadly, that didn't work either.
I now have a privatedata variable named "queryKundnamn" that in my example evaluates to:
SELECT "Sell-To Name" FROM "åtta_45$PV Case" WHERE "Order No_" = 'PO204331'
I then insert it to another privatedata variable:
kundnamn=[Database.Text:SQL="[Job.PrivateData:Key="queryKundnamn"]",Connection="printvis"]
I now get the error:
Error in line 1 of script Database.Text: Parse Error: expecting `error' or `'_'' or `';''
If I try the Query builder again with the string pasted, it works:
If I try inserting the variable "queryKundnamn" into the editor, which evaluates to the same string, it doesn't work:
Padawan
Post by Padawan »
Can you try this?
kundnamn=[Database.Text:SQL="[Job.PrivateData:Key='queryKundnamn']",Connection="printvis"]
I've changed the double quotes around the private data key to single quotes.
billy.olvestad
I tried it, but I got the same error message.
I have now solved it with scripting instead. Seems like in the script interface it works just fine.
Thanks for your help.
