how do I get the Switch-Stats-Values in NodeJS?
Greeting
Michael
Stats.NumberOfPages
Re: Stats.NumberOfPages
Hi Michael,
Switch 2021 Spring will bring PdfDocument and PdfPage Classes.
getNumberOfPages( ) is what you need.
It will be released on May 27th.
Hi Laurentd,
today ist May 27th, System requirements is uptodate, but I can't download 2021 spring. I would like to update my Switch-Dev-Version
Hi Michael,
The mail about Switch 2021 Spring has been sent an hour ago.
https://www.enfocus.com/en/support/rele ... ease-notes
Looking to get the Width and Height of the PDF Document. I have upgraded to Switch Fall 2021 my node script has be written previous to PdfDocument being added to Spring 2021.
What do I need to do to update my script as it is not reconising PdfDocument as a class?
My nodejs version is 14.15.0
Here is an example how to use PdfDocument and PdfPage classes on our EnfocusSW GitHub:
https://github.com/EnfocusSW/PdfProperties
Thanks Laurentd,
But from what can figure out my script is using verion 1.0.1 of types-switch-scripting, To update to fall 2021 I think I should be using version 21.1.0. What is the best way to update this without writing the script again?
The PdfDocument and PdfPage classes were introduced with Switch 2021 Spring.
This will update the type definition:
npm i @types/switch-scripting@1.1.0
Thanks Laurentd,
Really appreciate the replies.
I received an error '@types/switch-scripting@1.1.0' is not in the npm registry.
I just had to change npm i @types/switch-scripting@1.1.0
to
npm i @types/switch-scripting and it updated fine.
to
