Pantone mapping
magnussandstrom
Pantone mapping
Post by magnussandstrom »
Hi, I would like to setup an Action List that does the following :
Map alternate color space to PANTONE+ Lab values (But always keep paper suffix from incoming Pantone name - and map accordingly)
Malcolm Mackenzie
Re: Pantone mapping
Post by Malcolm Mackenzie »
You'll need to select spot by suffix and remap to the desired Pantone library.
Repeat for each suffix needed
The attachment Screenshot 2022-05-06 at 15.21.29.png is no longer available
Screenshot 2022-05-06 at 15.21.29.png (21.98 KiB) Viewed 18789 times
magnussandstrom
Re: Pantone mapping
Thanks Malcolm, I didn't realize that I could select by color suffix. Great!
magnussandstrom
Re: Pantone mapping
Hi again, unfortunatly the select by spot color suffix does not work for me. I'm guessing since the Action 'Remap all PANTONE library colors' applies to all PANTONE colors in the document regardless of the previous select.
Malcolm Mackenzie
Re: Pantone mapping
Hi Magnus
Ah, can you try using the change
Remap PANTONE library colors as per the grab.
This work here.
Screenshot 2022-05-09 at 11.24.14.png (217.13 KiB) Viewed 18743 times
magnussandstrom
Re: Pantone mapping
I can't get it to work unfortunatly. Here is a link to my test file and wanted result: https://bit.ly/3PafoaI
Malcolm Mackenzie
Re: Pantone mapping
Can you try this action please, attached zip.
Spot mapping 0522 U and C.eal.zip
(2.12 KiB) Downloaded 1464 times
JimmyHartington
Re: Pantone mapping
Post by JimmyHartington »
I have also given it a go.
My action list first selects PANTONE C and remaps. Then PANTONE U and remaps.
https://d.pr/f/m2TMXZ+
magnussandstrom
Re: Pantone mapping
Thanks Malcolm and Jimmy! You both came to the same conclusion. This is working!
john.dean@esko.com
Re: Pantone mapping
Post by john.dean@esko.com »
I'm late to this conversation, but in the past, I just renamed the Pantone colors since the name itself didn't matter until it got to the RIP. In this action list, every Pantone U gets changed to a C.
Rename Pantone U to C.eal.zip
(1.51 KiB) Downloaded 1421 times
Somewhat familiar with Enfocus products.
