Action
tdavey3715
Action
Post by tdavey3715 »
We are trying to decide on purchasing PitStop pro and wondering if we would be able to create an action that would convert text build in CMYK in a document to all black. I have downloaded a trial copy but cannot figure out how to do this if it is possible.
Thanks,
Tom
Malcolm Mackenzie
Re: Action
Post by Malcolm Mackenzie »
A few ways to do it.
There's a default action in PitStop
Check for Rich Black (K 85%, TAC 280%) turn to K
You could add a selection for text only etc.
jslater
Re: Action
Post by jslater »
There's also standard action list called If it looks Black and convert to Black. You could duplicate it and change the selection so it only affects text.
tdavey3715
Re: Action
I have tried running the file with the action selected and it does not convert the cmyk text to black.
david.ayha
Re: Action
Post by david.ayha »
upload your PDF file, for try to create an action.
Visit my Youtube Channel https://tinyurl.com/prepress-world
tdavey3715
Re: Action
I have attached the file I am trying to correct.
Thanks,
Tom
28304.zip
(166.86 KiB) Downloaded 1285 times
ibeg21
Re: Action
Post by ibeg21 »
This is one of solution
is only for text
change color 1.jpg (219.72 KiB) Viewed 14060 times
change color 2.jpg (197.61 KiB) Viewed 14060 times
Terkelsen
Re: Action
Post by Terkelsen »
The action "If it looks black and convert to Black" will not work on this document since the blue text doesn't look black ;)
If you just want to convert all text to black a simple action like this will do that:
Skærmbillede 2023-02-16 kl. 14.14.24.png (189.2 KiB) Viewed 13841 times
