Populate dropdown list in SwitchScripter
joaodaffonsojr
Post by joaodaffonsojr »
I´m using a node script that reads a directoty content and stores the values in a variable.
I want to make this result apear is a dropdown menu in the switch script so I can select one of the values.
I see that have this option on Switch Scripter but I have to enter manually the values.
Is it possible to populate this dropdown menu with the results from the variable ?
jan_suhr
Re: Populate dropdown list in SwitchScripter
Post by jan_suhr »
You have the property "Select from library". Then you get a list of values that you can populate from different sources.
You get the values from this Entry point in the script
getLibraryForProperty(s: Switch, flowElement: FlowElement, tag: string): Promise<string[]>
Jan Suhr
Color Consult AB
Sweden
Check out my apps
joaodaffonsojr
Thank you jan !
I´ll give a try !
joaodaffonsojr
jan_suhr wrote: Fri Feb 10, 2023 7:41 pm You have the property "Select from library". Then you get a list of values that you can populate from different sources.
Hi jan !
Sorry to bother you!
I'm trying to make getLibraryForProperty work,
but I really couldn't understand how to do it.
Below is the example I intend to use.
I have a directory that I need to be the "array" to populate the Library.
Can you give me a tip to solve this?
Thank you very much in advance!
//requirements
const fs = require("fs");
// replace with the path to your directory
const directoryPath = 'D:\\node_js\\dirlist\\sampleDoc';
//switch
async function jobArrived(s, flowElement, job) {
    //log directoryPath
    await job.log(LogLevel.Warning, "directoryPath " + directoryPath);
    async function getLibraryForProperty(s, flowElement, tag) {   //directory list array
    fs.readdir(directoryPath, (err, tag) => {
        if (err) {
            console.error('Error reading directory:', err);
            return;
        // Create a JSON array from the file names
        const jsonArray = JSON.stringify(tag);
    //log array
    await job.log(LogLevel.Warning, "directoryPath " + jsonArray);
    //remove input job
    await job.sendToSingle();
mkayyyy
Post by mkayyyy »
This is an example of how you'd implement the getLibraryForProperty entry point:
import * as fse from "fs-extra";
async function jobArrived(s: Switch, flowElement: FlowElement, job: Job) {
async function getLibraryForProperty(s: Switch, flowElement: FlowElement, tag: string): Promise<string[]> {
    let props: string[] = [];
    if (tag === "directoryPath") {
        //log directoryPath
        await flowElement.log(LogLevel.Warning, "directoryPath " + directoryPath);
        props = await fse.readdir(directoryPath);
    return props;
tdeschamps
Post by tdeschamps »
    let library = [];
    switch (tag) {
        case "case1":
            library = []; //Some code here;
            break;
        default:
            library = ["No Value found"];//optional
            break;
    return library;
joaodaffonsojr
This is the code that made it work.
thanks Jan , mkayyyy and tdeschampsBluewest !
    let props = [];
    if (tag === "Template") {
        const directoryPath = 'D:\\node_js\\dirlist\\sampleDoc\\';
        //creates de file list array
        props = fs.readdirSync(directoryPath);
    return props;
