Hello all, I'm trying to convert an Epoch time stamp to a standard date time and add that as a Private Data Key to the job. I am using a database call to send the Epoch value and convert it using a stored procedure in SQL Server. I get the correct date returned, but I am getting an 'unknown variable' error. I've tried changing the Database Variables from Date to Text but that doesn't see to have any affect. Any help would be appreciated!
Here's my statement in Switch:
[Database.Date:SQL="EXEC [DPI_ConvertEpochTime] [Job.PrivateData:Key="EpochTime"]",Connection="Tharstern",TimeZone="UTC"]
Sample value of "EpochTime" variable:
1675749785682
Here's my SP:
ALTER PROCEDURE [dbo].[DPI_ConvertEpochTime2] @Epoch VARCHAR
AS
DECLARE @EpochNumber BIGINT = cast(@Epoch as BIGINT)
DECLARE @DateTime DATETIME
SET @DateTime = (SELECT CAST(DATEADD(ms, CAST(RIGHT(@EpochNumber,3) AS SMALLINT),
DATEADD(s, @EpochNumber / 1000, '1970-01-01')) AS DATETIME2(3)))
SELECT @DateTime
Converting Epoch time to Date Time
- Screen Shot
- Switch Error.png (33.61 KiB) Viewed 7172 times
Re: Converting Epoch time to Date Time
Thanks for the tip jan_suhr. I use that app but didn't think about it for this.
I converted the seconds to days and used that number to add to 1970-01-01. Works like a charm!
Still would like to know what that error is all about though...
It sounds like the variable error will be coming from the square brackets around your stored procedure name
Try changing the database variable to:
[Database.Date:SQL="EXEC DPI_ConvertEpochTime [Job.PrivateData:Key="EpochTime"]",Connection="Tharstern",TimeZone="UTC"]Re: Converting Epoch time to Date Time
Thanks mkayyyy, that was it!mkayyyy wrote: ↑Mon Feb 13, 2023 6:32 pm It sounds like the variable error will be coming from the square brackets around your stored procedure name
Try changing the database variable to:Code: Select all
