I have built a custom check that check for a certain set of colors. Before the 2023 update it never flagged white (0/0/0/0) but now all of sudden it is flagging every object that is CMYK white.
I have added it the color set list but is still flagging the color.
Any thoughts?
Required Color Set - Flagging White
- Screenshot 2023-05-16 at 12.48.00 PM.png (58.51 KiB) Viewed 30276 times
Re: Required Color Set - Flagging White
Can you send me your action list and sample file?
loica (at) enfocus (dot) com
Well received, thanks.
I asked the team to investigate. I will come back to you as soon as I got feedback.
So, as it appears, we need to investigate further on the "require color set" action and in this specific case of tagged white. In the meantime, you can use the foolowing workaround to look for "white" objects and discard them from selection (as for the Pantone Colors).
https://fromsmash.com/p~By73n5xH-et
Let me know if that helps
Loic Aigon
Loic Aigon
Thanks!
I will download the workflow provided and test it out.
Any update on this issue?
This was logged in our system and need to be further evaluated. In the meantime, did you try the workaround I supplied?
