How to control a indesing file in a flow
ash-20
Post by ash-20 »
Hi Guys, I'm new to the switch environment kindly help me through this task.
I have a script that converts an Excel file to JSON and a separate script that reads the JSON and copies that content to the InDesign file.
JSON Looks:
"FileName": "A",
"layer_1": "1234",
"layer_2": "ABCD"
"FileName": "B",
"layer_1": "1234",
"layer_2": "abcd"
An InDesign File will behave like a template and Loop( copy the JSON contents and save a copy with the File name)
How I can replicate the same flow in the InDesing Configurator in Switch?
Thank you
AG
jan_suhr
Re: How to control a indesing file in a flow
Post by jan_suhr »
Jan Suhr
Color Consult AB
Sweden
Check out my apps
ash-20
Post by ash-20 »
jan_suhr wrote: Fri Sep 01, 2023 4:32 pm Check this:
https://www.enfocus.com/manuals/UserGui ... tions.html
hy I have gone through the document. What about the save option? because I need to update the next content from the JSON file in the same InDesign file and save it as a different file name.
jan_suhr
Post by jan_suhr »
You have the options in the InDesign elements properties
Jan Suhr
Color Consult AB
Sweden
Check out my apps
ash-20
Post by ash-20 »
jan_suhr wrote: Fri Sep 01, 2023 5:08 pm You have the options in the InDesign elements properties
InDesign elements properties, are you saying this PFA
If yes. I have a doubt. Now If I open (Script) a document and keep it as activeDocument (consider 123_XXX_v1.indd) add all my required info copied into the InDesign from the command option (Script), and save the file in the save option. Now how I can retain the "123_XXX_v1.indd" or keep the file inside the flow?
Screenshot 2023-09-01 at 9.17.32 PM.png (151.22 KiB) Viewed 148069 times
jan_suhr
Post by jan_suhr »
In one folder before the InDesign element you add one folder besides the InDesign elemet and drag a connection to the new folder and you will get a copy of the file in that folder.
Jan Suhr
Color Consult AB
Sweden
Check out my apps
ash-20
Post by ash-20 »
jan_suhr wrote: Fri Sep 01, 2023 6:05 pm In one folder before the InDesign element you add one folder besides the InDesign element and drag a connection to the new folder and you will get a copy of the file in that folder.
What you said is for keeping a copy of the original file in the flow (PFA, am I correct?). But I have a JSON condition that loops for a single activeDocument! suggest me on this case
Screenshot 2023-09-01 at 9.58.37 PM.png (93 KiB) Viewed 148065 times
jan_suhr
Post by jan_suhr »
Easiest solution is to split the JSON into each part for each file. Then that JSON file runs the InDesign document.
Jan Suhr
Color Consult AB
Sweden
Check out my apps
ash-20
Post by ash-20 »
jan_suhr wrote: Fri Sep 01, 2023 6:35 pm Easiest solution is to split the JSON into each part for each file. Then that JSON file runs the InDesign document.
hy That's a nice workaround, but I don't want to make any changes to the existing script so I going to try this way.
Initially, I will do the saveACopy for the .indd file with loop data in an outside folder (Foldername: Original output) using the Command Option and then a dummy save to move the .indd file to the out connection (save option)
And going to add a folder config and select a folder that is (Original output) using the Choose the folder option and add my files back to flow with my desired output format.
What am thinking will work?
jan_suhr
Post by jan_suhr »
It's not a workaround, that's how Switch works with metadata.
Switch can only read and use one set of values from an XML or JSON file.
If you have the Scripting module you can make a script that splits the data file and send each part to the InDesign element and it will create a new document from a template.
Next question is why don't you work with PDF-files, I suppose that is the final output. For PDF there are a bunch of tools that can solve this for you.
Jan Suhr
Color Consult AB
Sweden
Check out my apps
