Private data after reviewing the job
Is there some way to get access on the private data after the job is reviewed?
- Schermafbeelding 2023-11-10 160516.png (170.44 KiB) Viewed 41549 times
- magnussandstrom
Re: Private data after reviewing the job
You can always extract the private data before the job gets to the final output folder of the flow, even after the file is reviewed.
For example: [Job.PrivateData:Key="com.enfocus.PDFReviewModule.FileURL"]
Please explain what you would like to do.
I want to send a notification email incl. the review url and link name that the proof is reviewed to the customer. But after the job went through the 'reviewed file' connection, the private data [Job.PrivateData:Key="com.enfocus.PDFReviewModule.FileURL"] and [Job.PrivateData:Key="com.enfocus.Review.URL"] are not availeble anymore.
- magnussandstrom
Strange, I did a test and for me they are still there. Could you maybe post a screenshot of your flow?
The private data is available after 'other notification' and 'mail notification' but not after the 'reviewed file' connections
- Capture.PNG (58.51 KiB) Viewed 41290 times
- magnussandstrom
I thought you were talking about the old 'PDF Review Module', but I can see that you have the new 'Enfocus Review'. I'm not using that yet. Maybe the forum admin can rename this section to Enfocus Review or add a new section?
