HP SmartStream Designer Imposition Flow
evigil
Post by evigil »
Does anyone have a flow already that would like to share as a starting point?
Simple pdf in-impose-pdf out
I made a flow but in nerver creates a imposed pd.f Indesign opens but it never gets past the HP config what could I be missing? Any way to send it to someone for help?
ramziApp
Post by ramziApp »
HP SmartStream Designer VDP - multiple output formats
HP SmartStream Designer Imposition - multiple imposition templates
HP SmartStream Designer - end to end VDP and Imposition
Ramzi
Post by Ramzi »
evigil
Post by evigil »
What do I do for the Adobe Scripts Folder?
beastridge
Post by beastridge »
evigil wrote: Thanks
I would like to know this as well.
toonv
Post by toonv »
beastridge wrote: [quote=evigil]Thanks
Did you update your hp configurators to the latest version? In packmanager under the webtab you'll find version 3 of the hp configurators(hp jdf control is still version 2)and they shouldn't be asking for an Adobe Scripts Folder anymore.
corysawatzki
Post by corysawatzki »
Can someone help me find some templates for SmartStream? Someone had linked to here, but now it is gone. Thanks.
Cory Sawatzki
Spotlight Print Consulting
cory@spotlightpro.us
lombert
Post by lombert »
You use the same ones that you have on your "desktop version".
And you need to have the "desktop version" installed inside Indesign (or Quark) at your Switch-computer. Otherwise it will not work.
And I have noticed that I have to use one folder from SmartStream-confuguratorn there the "log-file" goes. So there have to be two output folders, one with the imposition and one for the log-file. The log-file can then direct be trash, no need to view it..
Between jobs!
