Does anyone have a flow already that would like to share as a starting point?
Simple pdf in-impose-pdf out
I made a flow but in nerver creates a imposed pd.f Indesign opens but it never gets past the HP config what could I be missing? Any way to send it to someone for help?
HP SmartStream Designer Imposition Flow
HP SmartStream Designer VDP - multiple output formats
HP SmartStream Designer Imposition - multiple imposition templates
HP SmartStream Designer - end to end VDP and Imposition
What do I do for the Adobe Scripts Folder?
evigil wrote: Thanks
I would like to know this as well.
beastridge wrote: [quote=evigil]Thanks
Did you update your hp configurators to the latest version? In packmanager under the webtab you'll find version 3 of the hp configurators(hp jdf control is still version 2)and they shouldn't be asking for an Adobe Scripts Folder anymore.
Can someone help me find some templates for SmartStream? Someone had linked to here, but now it is gone. Thanks.
You use the same ones that you have on your "desktop version".
And you need to have the "desktop version" installed inside Indesign (or Quark) at your Switch-computer. Otherwise it will not work.
And I have noticed that I have to use one folder from SmartStream-confuguratorn there the "log-file" goes. So there have to be two output folders, one with the imposition and one for the log-file. The log-file can then direct be trash, no need to view it..
Between jobs!
