But they noticed that some pages were missing in the reports my flow sent.
After performing multiple tests I've noticed that some pages are missing in the Ink Info report. What could be the cause of it?
Unfortunately it's not. Nevertheless even if it was it should report 0 ink usage, as it could be useful for decision making.JimmyHartington wrote: ↑Tue Jul 09, 2024 7:27 am I just got to ask the simple question.
Could it be blank pages?
If yes, I would of course still have them reported in the XML with zero as value.
I actually don't know what you mean by page label.tdeschampsBluewest wrote: ↑Tue Jul 09, 2024 9:10 am Could it be the label of the page in the report instead of the page number?
Do you have a missing ones in your label names?
Well, the default number is 100, but when I looked at it before I created this post it was 1000. Then, also before I posted, I tried changing it to 50.000.JimmyHartington wrote: ↑Wed Jul 10, 2024 7:54 am Not to say anything isn’t wrong with Pitstop Server.
But if you are running it through Switch, what have you set as the limit in the configurator?
You are right. It should truncate from the end.Soul Forge wrote: ↑Wed Jul 10, 2024 11:07 am Even if it was a problem with this limit, I guess the intended behaviour would be to truncate the last lines, not some in the middle, right?
Oh! I've seen a couple files with this problem before, some even using roman numerals, for whatever reason.tdeschampsBluewest wrote: ↑Thu Jul 11, 2024 5:17 pm In most case, page label = page index, but in some case if you added label to your pages, and remove some pages, the labels can mismatch the index.
Thanks for the workaround, I'll apply it in the flow!loicaigon wrote: ↑Fri Jul 26, 2024 8:49 am Hi all,
We identified a bug in the XML V3 report that doesn't translate information as it should. First, it's important to understand that in the PDF report, pages having a same amount of Ink coverage get gathered ( Page 2, 6, 15…). Here the xml report applies the same logic but doesn't report properly.
This is logged and will be fixed. The workaround right now is to choose XML v2 reports.
