Switch 24 Spring - Webhook v8.2
FloBluewest
Post by FloBluewest »
Hello Switch Masters and Switch Friends,
I updated switch to version 24 spring and webhook to version 8.2.
Since then, I can't communicate between postman and switch. Could you help me and tell me where I've made a mistake?
URL link I use :
localhost:51088/scripting/switchscan
Message I send with postman :
<?xml version="1.0"?>
<root>
    <id>147</id>
    <machineID>HP100K</machineID>
    <actualAction>
        <action>start</action>
        <date>2024-07-02 14:49:32</date>
    </actualAction>
</root>
Here is the webhook response
{"status":false,"error":"Cannot send webhook response: The script cannot be decrypted."}
EDIT : I downgraded to Webhook 8.1 and now it works.
germen@grafistore.nl
Re: Switch 24 Spring - Webhook v8.2
Post by germen@grafistore.nl »
It is not a Postman issue, it is an issue in version 8.2. We have this with JSON files too.
sander
Post by sander »
I just did a fresh install of Switch 24 Spring and tested the webhook with your XML and a random JSON, and it works perfectly.
The port is the same, 51088. The only thing missing in your post is whether it's http or https. I tested with https.
Engineering is not capable of reproducing the issue and there is the reaction from Sander. Can you confirm it is still there?
FloBluewest
Thanks Sander and Freddy for your answer.
I I tested again with the webhook 8.2 element, and I still get the same error. I attach the Postman result.
I'm running MacOS SOnoma 15.4 and my Postman version is 11.3.1.
Screenshot 2024-07-29 at 16.52.50.png (236.85 KiB) Viewed 12943 times
If I had exactly the same thing with webhook 8.1, I wouldn't have a problem. Am I missing something in the header or in the authorizations for version 8.2?
vernonvd
Post by vernonvd »
I am experiencing the same problem. updated to Switch 2024 and Webhook v8.2 and not working, reverted back to Webhook v8.1 and the problem is solved.
