Simple add bleed on document with no bleed
DJS
Post by DJS »
what is the best/simplest way to add 3mm bleed (mirroring and extending coloured boxes) and make the page 3mm bigger all around, have tried the bleed actions and they make the page larger, but I am struggling to make the images etc extend by 3mm where required and when I do the page stays as original size (ie A4)
loicaigon
Re: Simple add bleed on document with no bleed
Post by loicaigon »
Have you checked the default Action "Generate Bleed to 3mm if None, and Correctly Set all Page Boxes"
That should do it.
DJS
Post by DJS »
Thank you, thats great, it makes the page size bigger, which is what i wanted, but I also need the items that are closer than .5mm to the edge of the page to bleed, how would I do that?
loicaigon
Post by loicaigon »
Increase the value for "Bleed starts…"
DJS
Post by DJS »
thank you, I have tried that and the coloured box on page 2 stays as A4 size, it doesn't increase into the bleed - please see attached
Screenshot 1.png (61.4 KiB) Viewed 29052 times
Screenshot 1 - original A4 PDF (from word)
Screenshot 2.png (85.22 KiB) Viewed 29052 times
Screenshot 2 - successful action
Screenshot 3.png (98.74 KiB) Viewed 29052 times
Screenshot 3 - page 2 image remains as 210mm x 297
Any ideas?
loicaigon
Post by loicaigon »
Select the object and look at the inspector the exact coordinates and dimensions, shall the object be a slight portion further, then it would be discarded.
Otherwise, you can either contact support if the file is not sharable or post your PDF here.
DJS
Post by DJS »
Screenshot 2024-08-30 at 08.10.53.png (240.76 KiB) Viewed 29050 times
the black box remains as it was originally set, (A4)
loicaigon
Post by loicaigon »
Applying your properties, it works fine to me. Might be something with the file, is the TrimBox defined?
DJS
Post by DJS »
thank you for your reply, the file is a straight export/save from word, it is how we expect many of the files to come to us.
Crop/Art/Trim/Bleed all have the same value 210 x 297mm. I can't upload a PDF here can i?
DJS
Post by DJS »
hello again, just tried it with a document from inDesign, that works as expected, guessing there is something in the export from word which is causing the action not to perform?
loicaigon
Post by loicaigon »
you can use fromsmash.com if you want to upload file
DJS
Post by DJS »
thank you - pre and post action PDF's are here - https://fromsmash.com/Simple-add-bleed- ... h-no-bleed
JimmyHartington
Post by JimmyHartington »
The Trim Box is not defined in your file.
Ty recreating this action list and run it BEFORE adding bleed.
loicaigon
Post by loicaigon »
You can as well force define trim box in the inspector, but for automation purpose, you would indeed need to ensure that the trim is defined.
Many ways to get there.
DJS
Post by DJS »
Thank you very much.
So does this mean that there would need to be a separate PPP to manage PDFs that come out of MS Office?
The PPP will sit in a linear production process with one PPP doing all checks on all PDFs no matter what the original application the PDF came
