Search for Part of a Spot Colour Name
MJDS
Post by MJDS »
Is there an Action/Variable that can check for part of a spot colour name.
For example a file contains a spot colour called “cutterguide”
Could you search for part of the name “cut” and replace it with another spot colour name.
JimmyHartington
Re: Search for Part of a Spot Colour Name
Post by JimmyHartington »
This should be possible with the "Rename spot color"-action.
By using the regular expression:
.*cut.*
you can target spot colours with "cut" in the name.
MJDS
Post by MJDS »
Excellent does the trick.
Thanks for your help
JimmyHartington
If you need to test a regular expression I can recommend www.regex101.com
Here is one for testing names with cut.
https://regex101.com/r/m9tmPF/1
MJDS
Post by MJDS »
Thanks for the Info will be using this more in the future
loicaigon
Post by loicaigon »
You may also want to ensure you properly register to the next Enfocus Workshop dedicated to PitStop where we will cover Regular Expressions ;)
MJDS
Post by MJDS »
Looking forward to it Loic.
Nice one
