Is there an Action/Variable that can check for part of a spot colour name.
For example a file contains a spot colour called “cutterguide”
Could you search for part of the name “cut” and replace it with another spot colour name.
Search for Part of a Spot Colour Name
- JimmyHartington
Re: Search for Part of a Spot Colour Name
This should be possible with the "Rename spot color"-action.
By using the regular expression:
you can target spot colours with "cut" in the name.
.*cut.*
Excellent does the trick.
Thanks for your help
- JimmyHartington
If you need to test a regular expression I can recommend www.regex101.com
Here is one for testing names with cut.
https://regex101.com/r/m9tmPF/1
Thanks for the Info will be using this more in the future
You may also want to ensure you properly register to the next Enfocus Workshop dedicated to PitStop where we will cover Regular Expressions
Looking forward to it Loic.
Nice one
Nice one
