Variables Standards
bruno-92120
Variables Standards
Post by bruno-92120 »
Bonjour
Existe t il des variables standards ? Par ex la largeur et la hauteur (trimbox) pour effectuer un test d'homothétie ?
Merci pour votre réponse
rhd_ole
Re: Variables Standards
Post by rhd_ole »
bruno-92120 wrote: Mon Jan 06, 2025 4:51 pm Bonjour
Yes, when you go into the 'Define text with variables' - > Stats -> there are all types of default stats about the file such as Trim Height/Width. It uses Points as the unit of measure so you'll need to do a switch calculation to get it to metric/imperial
bruno-92120
Dear rhd-ole
Thanks a lot for your answer but after 10 min i'm not able to find the place of this menu :o
Would you be kind to make a screanshot ?
My app is in French...
Bests Regards
rhd_ole
Post by rhd_ole »
bruno-92120 wrote: Mon Jan 06, 2025 6:09 pm Dear rhd-ole
Bests Regards
I can't do French but I can translate.. Hope this helps! I would suggest watching a few videos on Switch also.
Screenshot 2025-01-06 at 12.39.51 PM.png (69.89 KiB) Viewed 46357 times
Screenshot 2025-01-06 at 12.39.24 PM copy 2.jpeg (180.19 KiB) Viewed 46357 times
bruno-92120
Thanks a lot again
but i use only PitStop Pro..
Thanks anyway
Best Regards
bens
Post by bens »
I don't think this is currently available in PitStop Pro. There are some actions (in the Action List editor) that have a list of page boxes, so if you're lucky the action you need has that. If not, you'll either have to use something external to PitStop Pro to get the values, or you may even be out of luck completely.
Terkelsen
Post by Terkelsen »
If what you are looking for is a way to ensure that all pages in a document have the same size, you can use "Check pages have same size" from the Action list editor. You can use this several times in an action list to check media-, trim- bleed box etc.
If you want to check that the pages have a specific size, you can use "Check page size". In that case you can use variables to do a smart preflight. When running the action, you will be asked to type the width and height to check for. In the variables you can even define a list of values that will be presented in a dropdown menu.
bruno-92120
Hello everyone
Thanks again for your comments
I was looking to perform a test to validate the homethetie between two sizes that's why i was looking some "standards variables" to use
I would have liked to extract the size of the page through know variable to valiate the homethetie
Terkelsen
Post by Terkelsen »
Since you only have PitStop Pro I think the only way is to combine the two PDFs into one and then run the "Check pages have same size".
loicaigon
Post by loicaigon »
Actually Erik, you are having a very great idea yet the limit might be that both pages formats may differ but still be homothetical.
