Assemble Job producing unwanted JOB DUPLICATE
Arthur
Post by Arthur »
Hello All;
I am getting a weird behaviour of the ASSEMBLE JOB processor, which set-up as per below pics is producing a duplicated job folder, so that I end up with 2 folders of the same name and identical set of files in them, one next to the other. Both on a Success connection. None being the Error out.
It should produce 1 assembled job, should it not ??
Could someone maybe advise on where is the issue and why is it producing duplicates when it should not ??
I have already spent few hours testing and fiddling with settings, but to no success so far.
Thank you ever so much for any help on this.
Arthur
Re: Assemble Job producing unwanted JOB DUPLICATE
Post by Arthur »
This can be closed I guess.
Wanted to delete it but maybe someone else may face such a trivial situation and get dumb like myself :)
So here is a quick explanation as what the problem was.
The folder following the assembler had 2 connections with no filter on them, so ultimately Switch created 2 instances of the job for each flow respectively. Because I put the flow on hold there, those 2 jobs accumulated in one folder creating confusion.
I am still laughing at myself, how obvious it was.
I hope someone else can also laugh at me here ;)
Cheers
LasseThid
Post by LasseThid »
Been there, done that!!! :lol:
