Define single-linge text with variables (Build Location path)
Ulrik
Post by Ulrik »
Are there anyone who knows how to search in Define single-linge text with variables (Build Location path)
Example: /SOAP-ENV:Envelope/SOAP-ENV:Body/ns1:GetObjectsResponse/Objects/Object/MetaData/BasicMetaData/Publication/Name
Here It return name d2 Kulør that I need.
But How to search the same name (d2 Kulør) if not in the same container, so I always find the right container
Best Regards Ulrik
Screen Shot 2019-01-22 at 14.37.43.png (30.08 KiB) Viewed 9678 times
r.zegwaard
Re: Define single-linge text with variables (Build Location path)
Post by r.zegwaard »
If you use "//Publication/Name" you should find all "Publication" nodes with a child "Name"
Thats because of the double slash
Ulrik
Post by Ulrik »
Hi r.zegwaard,
Thanks for your quickly reply, but I can't make it work I've tried but this one
/SOAP-ENV:Envelope/SOAP-ENV:Body/ns1:GetObjectsResponse/Objects/Object/MetaData/BasicMetaData"//Publication/Name"
Is that the way you mean ?
/Ulrik
ezFlow
Post by ezFlow »
Hello Ulrik,
Our Variable XPath app can solve this for you!
https://www.enfocus.com/en/appstore/pro ... able-xpath
