Excel to XML
LasseThid
Excel to XML
Post by LasseThid »
I downloaded a trial of the Excel to XML app from the Enfocus App Store, but even though I'm just playing around with a simple Excel file like this
Skärmavbild 2019-01-31 kl. 20.50.16.png (38.87 KiB) Viewed 10859 times
I get the following error when running this simple flow: Error in line 129 of script: Trying to access undefined member '0'
Skärmavbild 2019-01-31 kl. 20.47.58.png (48.31 KiB) Viewed 10859 times
with these settings
Skärmavbild 2019-01-31 kl. 20.48.08.png (101.35 KiB) Viewed 10859 times
Any ideas why this doesn't work?
I'm running Mac OS X 10.10.5 on the computer.
Thanks in advance
Malcolm Mackenzie
Re: Excel to XML
Post by Malcolm Mackenzie »
All looks fine.
I have the app running on a PC if you want to attach the file to test.
LasseThid
Re: Excel to XML
Post by LasseThid »
Thanks for the offer, but no need.
We will move the Switchserver from Mac to PC shortly to see if that resolves the issues we have with Switch failing to copy files to our Windows-servers every now and then. I downloaded the csv2xml app and it works like a treat, but it would be nice to figure out why the Excel to XML doesn't work.
jan_suhr
Re: Excel to XML
Post by jan_suhr »
Hello Lasse,
You could email me directly about this :-)
Have you turned on debugging in the messages? and can you send me the results you get then.
Something has gone wrong in the first step of the conversion and it can't read the temporary file that it use to build the XML.
Email me the results you get,please.
Jan Suhr
Color Consult AB
Sweden
Check out my apps
LasseThid
Re: Excel to XML
Post by LasseThid »
I just created that simple trial flow and didn't get further that that. Didn't know what to do when I got that error.
I will try to find the debugging and send the info to you.
Thanks.
jan_suhr
Re: Excel to XML
Post by jan_suhr »
The problem was a corrupt Excel-file that couldn't be converted to XML.
A new version of the app is submitted to Enfocus. This new version will send the job to the Problems job folder.
The new version would hopefully be available in a few days on the App store.
Jan Suhr
Color Consult AB
Sweden
Check out my apps
