Email preflight report
LasseThid
Post by LasseThid »
Hi guys.
I need a flow that will send me a preflight report on the resolution of the images in a pdf.
I created a PitStop Preflight Profile that creates a preflight report, but when I select to attach files I only get the original pdf file sent to me.
Any ideas where I'm going wrong?
lombert
Re: Email preflight report
Post by lombert »
You need to have a data and a report "line" from pitstop server. Then you get the report as a pdf.
Now you have the combine-line..
Between jobs!
LasseThid
Post by LasseThid »
Aha...
Why make it easy when you can make it complicated... :lol:
Thanks though! Works perfectly!
whitey666
Post by whitey666 »
Hi Im trying to do the same (well similar) but am fairly new to switch.
to start with i just want the report in a folder but i just get the original pdf
when you say:
are you referring to the 'carry this type of jobs/data or log or data with log????
could someone attach a screen shot of what this flow looks like ??? 8-)
Screen Shot 2017-10-12 at 17.25.22.png (52.16 KiB) Viewed 15360 times
lombert
Post by lombert »
Yes, That’s correct. The fixed/checked pdf is data, and the report is log. It can be txt, pdf you change that in the preflight.
The last is the pdf with meta-report..
Between jobs!
whitey666
Post by whitey666 »
Thanks lombert its working now :)
