Hold job for a specific time
Fist
Post by Fist »
I'm trying to get the "hold job" element to do the following.
On a inputfolder there are en undefined number of files (all pdf) each 15 minutes, 1 pdf file need to be released to the next folder which will pick-up the file and start a workflow.
No more then 1 fles each 15 minutes can pass.
For some reason (and for each setting I try) all the files are released at the set time.
Schermafbeelding 2018-05-22 om 07.39.09.png (181.14 KiB) Viewed 6840 times
r.zegwaard
Re: Hold job for a specific time
Post by r.zegwaard »
The outgoing connection of the "hold job" has an option "Space jobs apart" which you can set to 15 min.
Fist
Post by Fist »
I've mist that!
So now I have in the hold jobs element 1 minute delay (for the sake of testing) and in de Space job apart 1 minute
The Workflow as successfully validated and activated but the files do not run from one folder to the other.
Schermafbeelding 2018-05-22 om 08.44.42.png (215.16 KiB) Viewed 6836 times
Schermafbeelding 2018-05-22 om 08.42.13.png (188.6 KiB) Viewed 6836 times
Fist
Post by Fist »
Restarted switch and the flow was up-and-running.
F
