Check pagesize but allow portait and landscape
r.zegwaard
Post by r.zegwaard »
I know i can quite easy check a pdf on the trimbox-size. The size will be set with two variables (width and height).
But i want the check to allow both portrait AND landscape documents.
So if the variables are set:
width: 210mm / height: 297mm
And the trimbox is:
or
width: 297mm / height: 210mm
in both cases this should give a SUCCESS-result
Is this possible in one preflight-check?
Terkelsen
Re: Check pagesize but allow portait and landscape
Post by Terkelsen »
I think you will need to create an action to check this and then include the action in your preflight.
The action could look something like this:
Skærmbillede 2018-06-29 kl. 11.11.21.png (63.66 KiB) Viewed 7197 times
