Set view options in acrobat with Javascript
pcarvalho
Post by pcarvalho »
I have several pdf files in single page that i need to change the view options.
Can use a script script to invoke an action that do this?
Is is possible to do it directly in javascript? If so, where can i check the commands?
Thanks in advance
Re: Set view options in acrobat with Javascript
Does it need to be Acrobat Javascript?
PitStop has an action which allows you to change the initial view of a PDF:
http://www.enfocus.com/manuals/Extra/Ac ... _view.html
If you build an Action List with this Action, then you can run it on all your PDF files in an automated way using PitStop Server.
