JSON with special characters
mart3223
Post by mart3223 »
Hi All,
In my last Topic I was building a POST to a API. That is working fine right now with normal characters, the specials like "é" and "ë" are a problem right now. If I post this JSON with Postman everything is working fine:
{"parcel":{"address":"Kattegat 18","city":"Groningen","company_name":"Tëst ","country":"NL","email":"support@none.nl","name":"Tést","order_number":"1234","parcel_items":[{"description":"BOEKEN","quantity":1,"sku":"97890828","value":"0","weight":"1"}],"postal_code":"9723JP","sender_address":57138,"shipment":{"id":492},"telephone":""}}
If I use the same JSON in Enfocus Switch and make a POST I get a empty response, no error nothing. The header I use "Content-Type:application/json" does someone have a idea what i'm doeing wrong?
Kind regards, Martijn
Working with: Enfocus Switch, Pitstop Server, Quite Imposing, Kodak Nexpress (max 640mm sheets and 500grs) with most options (HD, Clear, Gold, White, Light-Black and Matt fuser), Polar Mohr D80 (compucut), Multigraf, Heidelberg, GMP, Duplo, Hohner.
Re: JSON with special characters
Post by gabrielp »
Curious -- does your web server/API get the request? Is it returning an empty response? Or is the request not even getting there?
mart3223
Post by mart3223 »
gabrielp wrote: Wed Feb 27, 2019 3:48 pm Curious -- does your web server/API get the request? Is it returning an empty response? Or is the request not even getting there?
Yes, it is returning a empty response. No error. If I use a JSON without special characters everything is working fine.
sander
Post by sander »
mart3223 wrote: Tue Feb 26, 2019 10:52 am If I use the same JSON in Enfocus Switch
Could be a encoding issue. How do you create your json on the Switch server, and how do you post?
e.g. If you create your json via FileWrite try using UTF-8: File.write(json, jsonBody,'UTF-8')
mart3223
Post by mart3223 »
We use the app "Make JSON" and the POST function in Enfocus. I have add some screenshots.
The setting of the POST (HTTP reuest app)
Schermafbeelding 2019-02-27 om 17.18.41.png (24.73 KiB) Viewed 22979 times
The JSON of the app "Make JSON"
aa
aa
Schermafbeelding 2019-02-27 om 17.18.56.png (60.42 KiB) Viewed 22979 times
sander
Post by sander »
Ouch, you posted in scripting. I’m not sure about these 3rd party apps. Do you have the scripting module?
sander
Post by sander »
Now I’m thinking of it, try this header, might work:
Content-Type: application/json;charset=utf-8
mart3223
Post by mart3223 »
I don'y have the scripting module. I have tested with the header "Content-Type: application/json;charset=utf-8" but that doesn't change anything. Can it be a bug in Switch?
Post by gabrielp »
mart3223 wrote: Wed Feb 27, 2019 4:08 pm
Can you confirm that with the logs from the API server? You could log out the request body received by the API server and see what Switch is doing to the payload.
