check if mediabox = trimbox
borisCM
Post by borisCM »
Hi all,
does any one else have an issue with the page boxes functionalities in pitstop?
you can't even check if the trimbox is defined? :cry:
the only option is to check the page box layout but who cares about a crop and bleed box??
i only need to know if the trimbox is there and if it smaller or equal to the mediabox.
it tried to do it via a variable in switch but the pdf page stats only look at the first page of a pdf.
i hope someone else found a solution for this? :)
Boris
Re: check if mediabox = trimbox
Post by abailescollins »
Is there a Trim Box.
Screen Shot 2019-09-10 at 2.48.40 PM.png (72.73 KiB) Viewed 11217 times
Action List attached.
Check if Trim Box exists.zip
(1.75 KiB) Downloaded 2256 times
Then for the Trimbox vs Media Box you need 'Check if Page Box is too large' and/or 'Check for differences in Page Boxes"
borisCM
Post by borisCM »
Hi thanks for that!
kind regards
Boris
borisCM
Post by borisCM »
bumped into some anoying issues, but i think i found a solution.
correct me if i'm wrong but 'Check for differences in Page Boxes' doesn't work because the value's you fill in have to match exactly, bigger then the value is also not okay?? don't understand why that is but.
anyway after some trial and error
because there is an option to compare the bleed box to the trim box, i checked the document for a missing bleedbox, if it is missing i'm adding (i hope this doesn't demand a lot of processing power) one that has the size of the media box and then do the check between the trim en media box. i included my solution.
I haven't tested it yet with a lot of files.
kind regards
Boris
TrimboxControle.zip
(1.51 KiB) Downloaded 2273 times
