Checkpoint pushing metadata forward
westleyw
Post by westleyw »
Hello all, we are new to Switch and have three inputs into the flow, a submit point and a checkpoint that is fed by both a Mail receive and Hotfolder.
The submit point is working great, all the metadata is entered and carries forward. All have the same information and same metadata selected and are named the same, however at the checkpoint we can enter data but it doesn't carry forward into the flow. Thinking it must be something simple.
Thanks for any advice!
Malcolm Mackenzie
Re: Checkpoint pushing metadata forward
Post by Malcolm Mackenzie »
Hi
if you can document the flow and either save the html file or as a PDF and post that will help find the issue.
Screenshot 2020-05-19 at 09.26.38.png (33.14 KiB) Viewed 5765 times
Terkelsen
Post by Terkelsen »
Are you aware that unless you have changed the default you will get two different "Data set names" from Submit Point and Check Point? If you look for the External Metadata Dataset you will have one called "Submit" and one called "Check".
