copy with Process.execute
hover27
Post by hover27 »
I want to copy files with Process.execute()
The reason therefor is, that I want to use some parameters, which aren't possible with Switch internal copy functin but with windwos copy.
(to copy two files together)
I tried to do this:
path1 = "\"C:\\folder1\\folder2\\myFile.txt\"";
path2 = "\"C:\\folder1\\folder2\\myFileNEW.txt\"";
var theCommand = 'copy ' + path1 + ' ' + path2 ;
job.log(1, theCommand);
Process.execute(theCommand) ;
job.log(1, Process.stdout);
I get the message:
Failed to run external process: copy C:\folder1\folder2\myFile.txt C:\folder1\folder2\myFileNEW.txt
Does anybody know, what is my mistake?
Thx
hover
Re: copy with Process.execute
Can you try this?
job.log(1, Process.stderr);
Stdout gives normal output, stderr error output
hover27
Post by hover27 »
the script does not go to the line with the log, so there is no message/log entry for job.log(1, Process.stderr)
when switch tries to execute Process.execute(theCommand)
there is a message from with type = Error and Module = Control:
Can't you just do like this in Switch:
hover27
Post by hover27 »
@jan_suhr
no, that is not what I need.
I need to copy two files together.
That is only possible with the internal command copy.
With the parameters of copy, I can copy two files into one file.
That's why I need to do it with Process.execute() and the copy command.
OK, so want to merge two files
With Switch Scripter you can read the file content from both files and merge that content in to a new file.
hover27
Post by hover27 »
Ah, that's a good idea.
I will try this.
laurentd
Post by laurentd »
Here is another possibility:
This is the right command: copy /b path1 + path2 outputPath
You can use the Execute command element and point to a .bat file
Output: file at path
If one file is the Switch job and the other file is a fixed file (eg when you add a header to your file):
Arguments: "%1" "%2"
Bat file content: copy /b “fixedFilePath” + %1 %2
If the two files are variable, first assemble them in a job folder, then use this:
Arguments: "%1\[Job.NestedName:Index='2',After=' ']" "%1\[Job.NestedName:Index='3',After=' ']" "%2"
Bat file content: copy /b %1 + %2 %3
hover27
Post by hover27 »
@laurentd
that is exactly what I want to do.
Thank you, good idea.
It seems, that Switch isn't able to process the copy command with Process.execute().
hover27 wrote: Thu Jan 14, 2021 6:19 pm @laurentd
It is probably because it isn't in the path for Switch to find it. A Switch Script is running in it's own environment and you have to adjust the path setting.
hover27
Post by hover27 »
jan_suhr wrote: Thu Jan 14, 2021 7:30 pm
That was my first thought also, but 'copy' is an internal DOS command. There is no separate path for it.
