Saxonica Saxon
jterrano
Saxonica Saxon
Post by jterrano »
We are attempting to remove an parent element that contains a child element of prodTypeCode='FFS'
When using Saxonica Saxon script, I have the script styled as followed :
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
    <xsl:output method="xml" version="1.0" encoding="UTF-8" indent="yes"/>
    <xsl:strip-space elements="*"/>
    <!-- identity transform -->
    <xsl:template match="@*|node()">
        <xsl:copy>
            <xsl:apply-templates select="@*|node()"/>
        </xsl:copy>
    </xsl:template>
    <xsl:template match="*[item/prodTypeCode='FFS']" />
</xsl:stylesheet>
But it will not remove the node that is tagged with FFS.
What am I doing wrong?
I will respond to this message with the code that I am applying this against...
jterrano
Re: Saxonica Saxon
Post by jterrano »
<?xml version="1.0" ?>
<orders>
	<order>
		<items>
			<item>
				<prodTypeCode>
					MOD
				</prodTypeCode>
			</item>
			<item>
				<prodTypeCode>
					FFS
				</prodTypeCode>
			</item>
			<item>
				<prodTypeCode>
					MOD
				</prodTypeCode>
			</item>
		</items>
	</order>
</orders>
(ive removed all unnecessary nodes...
Re: Saxonica Saxon
I have not tried getting the XSLT right, but based on the XML structure the XPath you use to select the item node with the value FFS cannot work.
//item[prodTypeCode='FFS']
does not select anything because of the extra line and the spaces that are part of the string. This XPath does select it:
//item[contains(prodTypeCode,'FFS')]
jterrano
Re: Saxonica Saxon
Post by jterrano »
So I saw what you meant about the tabs and we successfully processed this xml through saxonica saxon without using contains() but only if we MANUALLY remove the tabs... Do you happen to know of any saxonica saxon PE scripts that can be used to remove the tabs from the XML?
prodTypeCode - tabs.png (3.97 KiB) Viewed 6209 times
We would need to remove the tab BEFORE and AFTER (on the next line) that is associated with the prodType.
But if we have to apply it to everything, then so be it.
Re: Saxonica Saxon
If the value is 'FFS' and only 'FFS' then the only correct way of putting it into an XML is
<prodTypeCode>FFS</prodTypeCode>
Ergo, you should be looking that the code that creates the XML. Is that under your control? If not, then this app can come to the rescue: https://www.enfocus.com/en/appstore/pro ... ng-replace
