Merge one file to many files
franklintempleton
Post by franklintempleton »
I am attempting to create a Switch flow that does the following -
  • Submit a group of files - i.e. file A, file B, file C etc
  • File A must be merged in each of the other files, after page one of the file
I have created the following flow which routes file A to a folder to inject into the other files. I can use Inject Job to insert file A into one other file, but when I have multiple files I need file A inserted to I have to rename the file for every instance so that it inserts in the correct order of the new merged file. Is there a better way to do this?
IImage
switch flow.jpg (31.01 KiB) Viewed 4097 times
Re: Merge one file to many files
You can use pdftk to do that. You run it with Execute command or the app Run Command.
https://www.pdflabs.com/docs/pdftk-man-page/
