Using Submit Metadata in Pitstop Varibale Set
jpestell
Post by jpestell »
Hi All, how do I get Submit metadata fields into a Pitstop variable set for preflight. I currently have 3 fields width, height & number of pages I would like a preflight to verify the file against the data entered in the fields at the submit point.
Thanks in advance.
sander
Re: Using Submit Metadata in Pitstop Varibale Set
Post by sander »
This is the way.
1+2. Select your Variable Set.
3. Go with Text with Variables.
4+5. Define your Switch variable over here.
jpestell
Post by jpestell »
Thanks Sander, but I dont have 'Text with Variable' as an option?
sander
Post by sander »
Do you open the variable set via Switch or directly via PitStop server?
PitStop server:
Via Switch:
Notice the difference? :)
jpestell
Post by jpestell »
Thanks both I have now managed to get the variable set setup as below.
Variable Set
Variable Set
But I cant read these variable within a Preflight profile?
Preflight Profile
Preflight Profile
Hi
You need to set the variable type as "length". Number as you set is needed for abstract numbers like a number of pages, or separations.
When you come to check dimensions, you need length which introduces unit (mm, in…)
Hope that helps,
Loic
jpestell
Post by jpestell »
That worked thanks @Loic
