How to create a dummy file without moving the original file from the incoming folder
Romain Prisma Media
Post by Romain Prisma Media »
Hi !
I would like to be able to create a dummy job using "inject job" without moving the original file from the incoming folder.
What I need is to count (with Counter Plus) how many files are put in the folder but I need to keep files in the folder: this is the working folder of GMG Colorproof.
The flow
The properties of "inject job"
magnussandstrom
Re: How to create a dummy file without moving the original file from the incoming folder
Post by magnussandstrom »
With the app Inject Wildcard you can choose to keep the original file at it's place. And maybe the app Scan hierarcy could be beneficial for your flow.
Romain Prisma Media
Are you sure about that?
Inject Wildcard doesn't seem to be the right app
"This is the perfect solution when you don’t know the complete name of the job(s) to be injected or want to inject more than one job."
I did some test though and can't find any properties to keep file in the original folder
Capture d’écran 2024-07-05 à 09.52.19.png (71.92 KiB) Viewed 9285 times
It keeps on moving the file from the original folder whatever option is set up
magnussandstrom
'Delete after injection' could be translated to 'Remove the file from original folder after injection'. If you set this to No the file traveling down your flow is only a copy and the original file is kept in place.
The Folder apps bundle could also be interesting for you depending on what you are trying to do.
Could you explain in more detail what you are trying to achive? It's easier to give advice if we get the whole picture so to speak.
Romain Prisma Media
Delete after injection set to NO move the file from the original to the next folder as you can see on this screenshot
Capture d’écran 2024-07-05 à 10.42.30.png (98.8 KiB) Viewed 9276 times
The usecase is:
We have folders originally used by Epson (with GMG Colorproof software) printers where people put files to print (obviously :D )
We would like to count how many file are put in these folders without changing folders or flows from printers
magnussandstrom
In that case I would suggest you to de-route the file to Switch before putting it into the GMG hotfolder:
1. Set the original GMG input folder as your Switch flow input folder
2. Process in Switch
3. Send to new GMG hotfolder
You also already have a log-file in GMG colorproof that you can use in various ways..
Romain Prisma Media
Yeah I know :)
Thats what I wanna try to avoid (because i'm lazy and I don't want to change deposit folders or GMG processed folders:)
magnussandstrom
The issue with using the actual GMG hotfolder is that Switch doesn't know when the file arrives and disapears, you will have to poll for the files with a certain time interval and somehow not log the same file twice, etc etc.
Have you looked into ColorProof GO? It's the GMG ColorProof web-interface, were you can monitor active and printed jobs, among other things.
Romain Prisma Media
I'll check that
Maybe better than using Switch :)
Thx for you help !!
