Add Bleed Action List
RunDontStop
Post by RunDontStop »
A while back I started using the default action list "Generate Bleed to 3MM if Some, None, or Not Enough". Often it does a good job. Sometimes it works on some elements of a page and not on others. I've come to accept this, not expecting it to work 100% of the time.
I'm trying to make some improvements and I noticed something. Back when I started using the action list, it was constructed as this:
Generate Bleed - Original.png (113.65 KiB) Viewed 14979 times
Now, the default action list that comes with version 24 looks like this:
Generate Bleed - New.png (87.73 KiB) Viewed 14979 times
You can see, on the original, there are two selections being made, and the add bleed applied to each selection. In the revised, only one Add Bleed, with Select All. The descriptions of each action list changed accordingly. My question is: does anyone know what prompted Enfocus to make this adjustment to the default action list? Because I am currently using the original (copied into my Local action lists), I'm wondering if I should switch over to the new default and see some improvement.
Re: Add Bleed Action List
When selecting objects close to the page edge this excludes, for example, objects that cover the whole page. But these objects can be important for bleed generation - especially if transparency is involved.
Also, by generating bleed twice using a different object selection, the old Action List runs the risk of generating a different type of bleed for different objects. This can give visual artefacts. Doing it just once should give better results, and it's of course faster.
I suggest you try the new Action List, it should work better than before. And if it doesn't, you can always go back to the old one (and let Enfocus know).
