Add Trace Path question...
Tenzo
Post by Tenzo »
Hey all,
I have some PNGs that I am sending through Pitstop Server. I have altered them with ImageMagick to add a custom White contour around a Black Graphic with a transparent background. My questions is...
  • Is there a way to add a Trace Path around the White contour only to make it line art?
Re: Add Trace Path question...
There are two approaches you could take. If the white stroke width is know, you can simply get the trace done on the black part and extend/offset the stroke. If you can't presume that width, an option is to make the white, not white.
This can be done using a curve (gray in your case):
Then you can get the trace as you need:
In an Action List that would be:
Of course, there might be cases where you will need adjustments, but you get the idea.
Tenzo
Post by Tenzo »
loicaigon wrote: Tue Jan 21, 2025 6:25 pm If you can't presume that width, an option is to make the white, not white.
This definitely put me in the right direction!
I was able to expand the boxes and make the line art Red. However, why when I select the line art (See action list) does that not just change the traced path instead of making a new one?
double paths.png (43.28 KiB) Viewed 37349 times
Action List.png (6.83 KiB) Viewed 37349 times
I don't see a reason why you get a doubled path. I reproduced the action as you did and I don't get that result.
Are you sure they were no paths before you run the action?
Feel free to share files here so that we can further investigate.
Tenzo
Post by Tenzo »
loicaigon wrote: Wed Jan 22, 2025 9:12 am I don't see a reason why you get a doubled path. I reproduced the action as you did and I don't get that result.
I have resolved the double path issue. It turns out it was a "IBM" error.
I had a Preflight Profile calling the action & the Action List selected in the Switch app.
So, all is good for now!
Thanks again for your help @loicaigon!
It is greatly appreciated!
