Rename file based on contents
netaware
Post by netaware »
Is it possible for Switch to rename a text file or add a suffix/prefix based on its size or contents?
Or do I need to write a script?
Thanks.
JimmyHartington
Re: Rename file based on contents
Post by JimmyHartington »
If it is the file size, you have the variable [Job.Size] which can be used in a rename element.
For contents you could use the Run Command app.
The it should be a command which outputs the contents of the file to the standard output, which then is private data that can be used to rename the file.
For example if the structure is consistent and the textfile needs to be renamed with the text in the second line of the text-file.
On macOS this can be done with this code:
sed -n '2p' filename.txt
That could the be the command for Run Command.
In the Standard Output private data tag you will then have the second line and can use that to rename.
Depending on the complexity of the contents of the text file you may find this app useful: https://www0.enfocus.com/en/appstore/product/txt-pickup
netaware
Post by netaware »
Thanks but I think I maybe explained my problem wrong. I am looking to assemble a job from 2 different incoming folders, Folder 1 and Folder 2.
I assemble the job folder with 2 files, one from each incoming folder, based on a segment of the name, 1-23 positions.
This works fine except for most files. However, I have 2 files in each incoming folder that are almost exactly the same name:
Folder 1 - 3-M-JTSPAW-22025-2025100013-CDBD14.txt and 3-M-JTSPAW-22025-2025100013-CDBD15.txt
Folder 2 - 3-M-JTSPAW-22025-2025100028-CDC5BB.txt and 3-M-JTSPAW-22025-2025100028-CDC5BC.txt
NOTE: the first 11 characters are always the same, 3-M-JTSPAW-
The assemble app is assembling both files from Folder 1 together and both files from Folder 2 together.
How can I get it where it puts one file from Folder 1 and one file from Folder 2 together?
I understand the original filenames are close but I cannot do anything about it. I have rename job app remembering the original name.
Assemble job settings
This is what i am getting with my assemble job
Thanks for your suggestions!
JimmyHartington
I am a bit unsure about what you want to achieve.
Is the files assembled correctly, but the name of the job-folder is wrong?
magnussandstrom
Post by magnussandstrom »
netaware wrote: Mon Jul 07, 2025 8:37 pm How can I get it where it puts one file from Folder 1 and one file from Folder 2 together?
If you want to assemble files from different job folders you need to first add a 'Job dismantler' then use 'Assemble job'.
You have described your input, but not your desired output, at least not in a clear way.
There is a contradiction in the description: you mention positions 1-23, but in the screenshot the value is 1-15.
There is something puzzling in the description: "This works fine" suggests it works fine, but "except for most files" suggests that it does not work fine at all.
Anyway, you have input hot folder "Folder 1" with the following files:
and input hot folder "Folder 2":
I assume, so please confirm or contradict, that both "Folder 1" and "Folder 2" have a connection to the same "Assemble job" element.
Desired result after assemble job:
now it is your turn, and explain why a certain combination of files have to be assembled.
netaware
Post by netaware »
Sorry if I confused you so let me try to explain.
I need to run a few hundred files. The desired output i am expecting is a job folder with two files, one from Folder 1 and 1 from Folder 2.
This flow will comparing a before file, ie Folder 1, and an after file, ie Folder 2. The files in either folder are similar so i am using the first 23 characters of the filename to assemble a job folder with 2 files.
This method of assembling a job works for my hundreds of file pairs except the 4 files i have mentioned.
The problem i am having with these files is assemble job is taking both files from Folder 1 and outputting them to a job folder, and doing the same thing to the files in Folder 2.
I need assemble job to take one file from Folder 1 and one file from Folder 2 and output them to a job folder
The job folders, after assemble, i am expecting is:
3-M-JTSPAW-22025-2025100013-CDBD14.txt (Folder 1) and 3-M-JTSPAW-22025-2025100028-CDC5BB.txt (Folder 2) -> Job folder 1
and
3-M-JTSPAW-22025-2025100013-CDBD15.txt (Folder 1) and 3-M-JTSPAW-22025-2025100028-CDC5BC.txt (Folder 2) -> Job folder 2
I hope this clears up things. If not then i am sorry for wasting your time.
Thank you
It is clear that the first 23 characters are not a 100% solid way of combining the files because all 4 have the same first 23 characters. The obvious question: is there some other property that is common to the files that do belong together? If there was, you could concatenate both properties (the first 23 characters and that something else) in the "Job identifier" property and the problem would be solved.
Based on the filenames the only strategy I can think of is the following: if there is more than 1 file in one input folder with the same first 23 characters, there must also be the same number of files in the other input folder with the same first 23 characters, in which case they must be assembled in alphabetical order.
Correct? That is scriptable, but I would first investigate if there isn't some other piece of information, possibly from the PDF itself, that can be used to make the desired combination.
netaware
Post by netaware »
So i just ended up writing a script to append any dup filenames with a incremental number
Thanks for your help
