Location Path Metadata List
schmitzdp
Post by schmitzdp »
is there a trick to retrieve the value following the key given in a structure like the one below?
Instead of using this way?
[Metadata.Text:Dataset="Payload",Model="JSON",Path="/data/fields/2/value"]
Thank you.
JimmyHartington
Re: Location Path Metadata List
Post by JimmyHartington »
I try to use the syntax below.
[Metadata.Integer:Dataset="RollLabel",Model="XML",Path="/field-list/field[tag='TAGNAME']/value"]
This has often helped me with a submit point when adding new fields, so the number changes for the values.
schmitzdp
Post by schmitzdp »
I try this but without success.
Have I made a mistake?
[Metadata.Text:Dataset="Payload",Model="JSON",Path="/data/fields[key='question_8zkRMO']/value"]
or
[Metadata.Integer:Dataset="Payload",Model="JSON",Path="/data/fields[key='question_8zkRMO']/value"]
JimmyHartington
Sorry. I missed yours data was JSON.
I think my method only works with XML.
Correct, Jimmy, your method will only work with XML but it is easy to convert a JSON to XML with "JSON pickup - Pickup result - XML".
