is there a trick to retrieve the value following the key given in a structure like the one below?
Instead of using this way?
[Metadata.Text:Dataset="Payload",Model="JSON",Path="/data/fields/2/value"]
Thank you.
[Metadata.Integer:Dataset="RollLabel",Model="XML",Path="/field-list/field[tag='TAGNAME']/value"]Code: Select all
[Metadata.Text:Dataset="Payload",Model="JSON",Path="/data/fields[key='question_8zkRMO']/value"]Code: Select all
[Metadata.Integer:Dataset="Payload",Model="JSON",Path="/data/fields[key='question_8zkRMO']/value"]
