Length of a cut path as a variable
Danp
Post by Danp »
Hi there,
Is it possible to save the length of a measured cut path as a variable and then use this as part of the file name?
Thanks in advance for any help.
Dan
JimmyHartington
Re: Length of a cut path as a variable
Post by JimmyHartington »
If you have Switch it is possible.
Have an action list which check if length of cut path is less than 0.
The XML-report will then have the measured length.
This can be used as a variable in Switch to rename the file.
Royal TSX-Flow-server03-2025-09-19 at 15.36.12@2x.jpg (217.61 KiB) Viewed 5367 times
Danp
Post by Danp »
Thanks very much Jimmy, will give that a go.
Best regards,
Dan
